| ExtremeWireless ™ | ||||||
| AP Series | Product Number | Product Description | Product Long Description | Min FW Version | Supported FW Versions | XCloud Support |
| AP3917 - 802.11ac Wave 2 and 802.11abgn, Cloud and IoT ready access points, designed to operate in outdoor environments. The AP3917 offers multiple connectivity options: WiFi 2.4GHz, WiFi 5GHz, and BLE/802.15.4 (Thread network) for location services or extended connectivity to Internet of Things (IoT) sensors and devices. | 31050 | WS-AP3917i-FCC | AP3917 offers 802.3at Power over Ethernet (PoE) and easy installation on most surfaces. Optional accessories are available for fixed wall mounting, directional wall mounting, or pole mounting. Other features include: dynamic radio management, spectrum analysis with interference classification, beamforming, multi-user MIMO, self-forming and self-healing meshing, security, role-based authentication, authorization, and access control to ensure consistent and secure connectivity to users and sensors. The 2×2:2 platform can deliver up to 1.2 Gbps over-the-air-performance and up to 50,000 packets per second on the wired port using a unique flow-based architecture that provides consistent performance even when enforcing extensive application-based (aka Layer 7) service requirements. Restricted Regulatory Domain: FCC (Available in the U.S., Puerto Rico, and Colombia). | v10.41.02 | v10.41.02 (latest) | Yes |
| 31051 | WS-AP3917i-ROW | Restricted Regulatory Domain: ROW (Available in regions other than U.S., Puerto Rico, and Colombia). | v10.41.02 | v10.41.02 (latest) | Yes | |
| 31055 | WS-AP3917e-FCC | The AP3917e model requires professional installation and includes four standard N-type antenna connectors supporting 2.4GHz or 5GHz band antennas, and a standard N-type connector for a 2.4GHz antenna for BLE/802.15.4 support. Restricted Regulatory Domain: FCC (Available in the U.S., Puerto Rico, and Colombia). | v10.41.02 | v10.41.02 (latest) | Yes | |
| 31056 | WS-AP3917e-ROW | Restricted Regulatory Domain: ROW (Available in regions other than U.S., Puerto Rico, and Colombia). | v10.41.02 | v10.41.02 (latest) | Yes | |
| AP3915i - 11ac Wave 2 AP, Cloud and IoT ready indoor ceiling mount model with five internal antennas. | 31028 | WS-AP3915i-FCC | Supports the IoT application. This AP comes with an 802.3 PoE PD for powering. Dual-band, dual radio,2 x Multi-User MIMO. Mounting options include: dry wall, ceiling, or solid surface, and can be suspended on a ceiling or attached to a beam. Restricted Regulatory Domain: FCC (Available in the U.S., Puerto Rico, and Colombia). | v10.41.01 | v10.41.(latest) | Yes |
| 31029 | WS-AP3915i-ROW | Restricted Regulatory Domain: ROW (Available in regions other than U.S., Puerto Rico, and Colombia). | v10.41.01 | v10.41.(latest) | Yes | |
| AP3915e - 11ac Wave 2, Cloud and IoT ready indoor ceiling mount model with three external antennas. | 31031 | WS-AP3915e-FCC | AP3915e has three external antennas (two for WiFi Radios and one for a Bluetooth radio). AP3915e operates with dual band antennas only. Both antenna sockets should connect to identical antennas. Restricted Regulatory Domain: FCC (Available in the U.S., Puerto Rico, and Colombia). | v10.41.01 | v10.41.(latest) | Yes |
| 31032 | WS-AP3915e-ROW | Restricted Regulatory Domain: ROW (Available in regions other than U.S., Puerto Rico, and Colombia). | v10.41.01 | v10.41.(latest) | Yes | |
| AP3916ic - Cloud-ready, with an integral security camera. An 11ac, Wave 2 AP that extends your Wireless LAN and provides simultaneous Wi-Fi service, BLE or 802.15.4 coverage and security. Supports the IoT application. The integral ONVIF compatible security camera is connected to an internal wired Ethernet port. The AP can be mounted on the ceiling or wall. | 31034 | WS-AP3916ic-FCC | Restricted Regulatory Domain: FCC (Available in the U.S., Puerto Rico, and Colombia). | v10.31.01 | v10.31.(latest) or v10.41.(latest) | Yes |
| 31035 | WS-AP3916ic-ROW | Restricted Regulatory Domain: ROW (Available in regions other than U.S., Puerto Rico, and Colombia). | v10.31.01 | v10.31.(latest) or v10.41.(latest) | Yes | |
| AP3912 -- Cloud-ready, Wall-plate , Dual band, Dual Radio 802.11ac/abgn, 2x2:2 MIMO Indoor Wave 2 access points. | 31025 | WS-AP3912i-FCC | Includes a four internal antenna array. Restricted Regulatory Domain: FCC (Available in the U.S., Puerto Rico, and Colombia). | v10.21.01 | v10.31.(latest) or v10.41.(latest) | Yes |
| 31026 | WS-AP3912i-ROW | Includes a four internal antenna array. Restricted Regulatory Domain: ROW (Available in regions other than U.S., Puerto Rico, and Colombia). | v10.21.01 | v10.31.(latest) or v10.41.(latest) | Yes | |
| AP3935 -- Dual band, Dual Radio 802.11ac/abgn, 4x4:4 MIMO Indoor Wave 2 access points. | 31012 | WS-AP3935i-FCC | Includes an eight internal antenna array and active/active E/N data ports. Restricted Regulatory Domain: FCC (Available in the U.S., Puerto Rico, and Colombia). | v10.01.01 | v10.31.(latest) or v10.41.(latest) | Yes |
| 31013 | WS-AP3935i-ROW | Includes an eight internal antenna array and active/active E/N data ports. Restricted Regulatory Domain: ROW (Available in regions other than U.S., Puerto Rico, and Colombia). | v10.01.01 | v10.31.(latest) or v10.41.(latest) | Yes | |
| 31014 | WS-AP3935e-FCC | Includes eight, external , N-type jack connectors (4 connectors per band) for external antenna array and active/active E/N data ports. Regulatory Domain: FCC (Available in the U.S., Puerto Rico, and Colombia). | v10.01.01 | v10.31.(latest) or v10.41.(latest) | No | |
| 31015 | WS-AP3935e-ROW | Includes eight, external , N-type jack connectors (4 connectors per band) for external antenna array and active/active E/N data ports. Regulatory Domain: ROW (Available in regions other than U.S., Puerto Rico, and Colombia). | v10.01.01 | v10.31.(latest) or v10.41.(latest) | No | |
| 31020 | WS-AP3935i-IL | Includes an eight internal antenna array and active/active E/N data ports. Restricted Regulatory Domain: IL (Available in Isreal). | v10.11.02 | v10.31.(latest) or v10.41.(latest) | Yes | |
| AP3965 -- Dual band, Dual Radio 802.11ac/abgn, 4x4:4 MIMO Outdoor Wave 2 access points. | 31016 | WS-AP3965i-FCC | Includes an eight internal antenna array and active/active E/N data ports. Restricted Regulatory Domain: FCC (Available in the U.S., Puerto Rico, and Colombia). | v10.01.02 | v10.31.(latest) or v10.41.(latest) | Yes |
| 31017 | WS-AP3965i-ROW | Includes an eight internal antenna array and active/active E/N data ports. Regulatory Domain: ROW (Available in regions other than the U.S., Puerto Rico, and Colombia). | v10.01.02 | v10.31.(latest) or v10.41.(latest) | Yes | |
| 31018 | WS-AP3965e-FCC | Includes eight, external , N-type jack connectors (4 connectors per band) for external antenna array and active/active E/N data ports. Regulatory Domain: FCC (Available in the U.S., Puerto Rico, and Colombia). | v10.01.02 | v10.31.(latest) or v10.41.(latest) | No | |
| 31019 | WS-AP3965e-ROW | Includes eight, external , N-type jack connectors (4 connectors per band) for external antenna array and active/active E/N data ports. Regulatory Domain: ROW (Available in regions other than the U.S., Puerto Rico, and Colombia). | v10.01.02 | v10.31.(latest) or v10.41.(latest) | No | |
| AP3805 -- Dual band, Dual Radio 802.11ac/abgn, 2x2:2 MIMO Indoor Wave 1 access points. | 30912 | WS-AP3805i-FCC | Includes four internal antenna array. Restricted Regulatory Domain: FCC (Available in the U.S., Puerto Rico, and Colombia). | v10.01.04 | v10.31.(latest) or v10.41.(latest) | Yes |
| 30913 | WS-AP3805i-ROW | Includes four internal antenna array. Restricted Regulatory Domain: ROW (Available in regions other than U.S., Puerto Rico, and Colombia). | v10.01.04 | v10.31.(latest) or v10.41.(latest) | Yes | |
| WS-AP3805i | WS-AP3805i | Indoor AP with internal antenna assemblies. Supports the 802.11ac wireless standards. | v9.15.01 | v9.21.(latest), v10.31.(latest) , or v10.41.(latest) | No | |
| WS-AP3805e | WS-AP3805e | Indoor AP with external antenna connectors. Supports the 802.11ac wireless standards. | v9.21.01 | v9.21.(latest) or v10.31.(latest) | No | |
| WS-AP3805i | WS-AP3805i | Indoor AP with internal antenna assemblies. Supports the 802.11ac wireless standards. Mfg rev 5K or greater. | v9.21.10 | v9.21.(latest), v10.31.(latest), or v10.41.(latest) | No | |
| WS-AP3805e | WS-AP3805e | Indoor AP with external antenna connectors. Supports the 802.11ac wireless standards. Mfg rev 5K or greater. | v9.21.10 | v9.21.(latest), v10.31.(latest), or v10.41.(latest) | No | |
| AP3801 | WS-AP3801i | WS-AP3801i | Indoor AP with internal antenna assemblies. Supports the 802.11ac wireless standards. | v9.21.01 | v9.21.(latest), v10.31.(latest), or v10.41.(latest) | No |
| WS-AP3801i | WS-AP3801i | Indoor AP with internal antenna assemblies. Supports the 802.11ac wireless standards. Mfg rev 5F or greater | v9.21.10 | v9.21.(latest) , v10.31.(latest), or v10.41.(latest) | No | |
| AP3825 | WS-AP3825i | WS-AP3825i | Indoor AP with internal antenna assemblies. Supports the 802.11ac and 802.11n wireless standards. | v9.01.01 | v9.21.(latest), v10.31.(latest), or v10.41.(latest) | No |
| WS-AP3825e | WS-AP3825e | Indoor AP with external antenna connectors. Supports the 802.11ac and 802.11n wireless standards. | v9.01.01 | v9.21.(latest), v10.31.(latest), or v10.41.(latest) | No | |
| WS-AP3825i | WS-AP3825i-1 | Indoor AP with internal antenna assemblies. Supports the 802.11ac and 802.11n wireless standards. App ID WS-3825i-1 (mfg rev 5L or greater). Units produced after May 2016. | v9.21.08 or v10.01.04 | v9.21.(latest), v10.31.(latest), or v10.41.(latest) | No | |
| WS-AP3825e | WS-AP3825e-1 | Indoor AP with external antenna connectors. Supports the 802.11ac and 802.11n wireless standards. App ID WS-3825e-1 (mfg rev 5L or greater). Units produced after May 2016. | v9.21.08 or v10.01.04 | v9.21.(latest), v10.31.(latest), or v10.41.(latest) | No | |
| AP3865 | WS-AP3865e | WS-AP3865e | Outdoor AP with external antenna assemblies. Supports the 802.11a, 802.11b, 802.11g, 802.11n, and 802.11ac protocols. | v9.12.01 | v9.21.(latest), v10.31.(latest), or v10.41.(latest) | No |
| AP3705 | WS-AP3705i | WS-AP3705i | Indoor AP with internal antennas, 2x2x2 802.11abgn | v8.11.05 | v9.21.(latest), v10.31.(latest), or v10.41.(latest) | No |
| AP3710 | WS-AP3710i | WS-AP3710i | Indoor AP with internal antennas, 3x3x3 802.11abgn | v8.21.04.24 | v9.21.(latest), v10.31.(latest), or v10.41.(latest) | No |
| WS-AP3710e | WS-AP3710e | Indoor AP with external antennas, 3x3x3 802.11abgn | v8.21.04.24 | v9.21.(latest), v10.31.(latest), or v10.41.(latest) | No | |
| AP3715 | WS-AP3715i | WS-AP3715i | Indoor AP with internal antennas, 3x3x3 802.11abgn | v8.31.01 | v9.21.(latest), v10.31.(latest), or v10.41.(latest) | No |
| WS-AP3715e | WS-AP3715e | Indoor AP with external antennas, 3x3x3 802.11abgn | v8.31.01 | v9.21.(latest), v10.31.(latest), or v10.41.(latest) | No | |
| AP3765 | WS-AP3765i | WS-AP3765i | Outdoor AP with internal antennas, 3x3x3 802.11ac, 802.11abgn | v8.21.01 | v9.21.(latest), v10.31.(latest), or v10.41.(latest) | No |
| WS-AP3765e | WS-AP3765e | Outdoor AP with external antennas, 3x3x3 802.11ac, 802.11abgn | v8.21.01 | v9.21.(latest), v10.31.(latest), or v10.41.(latest) | No | |
| AP3767 | WS-AP3767e | WS-AP3767e | Outdoor AP with external antennas, 3x3x3, 802.11n, 802.11a/b/g | v8.21.01 | v9.21.(latest), v10.31.(latest), or v10.41.(latest) | No |
| AP3660 | WS-AP3660e | WS-AP3660e | Outdoor AP with 6 ports for external antennas, dual radio 802.11a/b/g/n | N/A | v9.21.(latest) | No |
| AP 3640-ROW/NAM/IL | WS-AP3640i/e | WS-AP3640i/e | Indoor APs with internal/external dualband antennas, dual radio 802.11a/b/g/n | N/A | v9.21.(latest) | No |
| AP3630-ROW/NAM/IL | WS-AP3630i/e | WS-AP3630i/e | Indoor APs with internal/external dualband antennas, dual radio 802.11a/b/g/n standalone | N/A | v9.21.(latest) | No |
| AP3620-/ IL | WS-AP3620i/e | WS-AP3620i/e | Thin APs with internal/external dual-band antennas, dual radio 802.11a/b/g/n | N/A | v9.21.(latest) | No |
| AP3610/- IL | WS-AP3610i | WS-AP3610i | Indoor AP with six internal antenna array, Dual Radio 802.11a/b/g/n, 3x3:2. -IL version has a Restricted Regulatory Domain: IL (Available in Isreal). | N/A | v9.21.(latest) | No |
| AP 3605-IL | WS-AP3605i | WS-AP3605i | Dual radio 802.11a/b/g/n thin AP with internal dual-band. -IL version has a Restricted Regulatory Domain: IL (Available in Isreal). | N/A | v9.21.(latest) | No |
| AP2660-/IL | WS-AP2660i/e | WS-AP2660i/e | Outdoor industrial AP with internal/external antennas, dual radio 802.11a/b/g. -IL version has a Restricted Regulatory Domain: IL (Available in Isreal). | N/A | v9.21.(latest) | No |
| AP2650-/IL | WS-AP2650i/e | WS-AP2650i/e | Outdoor industrial AP with internal/external antennas, dual radio 802.11a/b/g. -IL version has a Restricted Regulatory Domain: IL (Available in Isreal). | N/A | v9.21.(latest) | No |
| AP2640-EU | WS-AP2640i/e | WS-AP2640i/e | Dual radio 802.11a/b/g standalone APs with internal/external antennas that can optionally be configured to operate in thin mode -EU version has a Restricted Regulatory Domain: Rest of World. | N/A | v9.21.(latest) | No |
| AP2630-EU | WS-AP2630i/e | WS-AP2630i/e | Dual radio 802.11a/b/g standalone APs with internal/external antennas that can optionally be configured to operate in thin mode. Restricted Regulatory Domain: Rest of World. | N/A | v9.21.(latest) | No |
| AP2620-/ IL | WS-AP2620i/e | WS-AP2620i/e | Dual radio 802.11a/b/g thin APs with internal/external antennas. -IL version has a Restricted Regulatory Domain: IL (Available in Isreal). | N/A | v9.21.(latest) | No |
| AP2610- /IL | WS-AP2610i/e | WS-AP2610i/e | Dual radio 802.11a/b/g thin APs with internal/external antennas. -IL version has a Restricted Regulatory Domain: IL (Available in Isreal). | N/A | v9.21.(latest) | No |
| AP2605-/ IL | WS-AP2605i/e | WS-AP2605i/e | Dual radio 802.11a/b/g thin APs with internal/external antennas. -IL version has a Restricted Regulatory Domain: IL (Available in Isreal). | N/A | v9.21.(latest) | No |
